Harley Big Twin & Sportster Dyna S Single Fire Ignition - Dyna Tek DS6-2
SKU 32-7777
$209.99
2099 ENTRIES 🎟️
$209.99 - $209.99
$209.99
2099 ENTRIES 🎟️
Dyna S single fire ignition has the features of the Dyna S but fires the front and rear cylinders independently of each other which allows accurate timing of each cylinder. Stock ignition system fires both cylinders at the same time which has a wasted spark on the exhaust stroke. This eliminates this inherent problem. Use advance assembly on 1980-up models. Ignition can be used with single or dual plug heads. Installation instructions (PDF). Fits 1970-2003 Harley Big Twin, Dyna, FX (Super Glide), FXR, Softail, Sportster, Touring, and Shovelhead models.
Dyna Tek #: DS6-2
  • Suggested to use with advance assembly on 1980-up models.
1970-1984 FL
1986-1999 FLST
1980-1999 FLT
1971-1984 FX
1991-1999 FXD
1982-1994 FXR
1984-1999 FXST
1971-2003 XL
