Harley Dyna Mini Coil Set 0.5 Ohms Single Output Towers - Dyna Tek DC12-2
SKU 32-9344
$139.99
1399 ENTRIES 🎟️
$139.99 - $139.99
$139.99
1399 ENTRIES 🎟️
Dyna miniature coil set feature single output towers and.5 ohms primary resistance. Designed for use with Dyna TC-88 series ignitions and should not be used with Dyna S ignition systems. Coil set measures 4.2 inch x 2.3 inch x 1.6 inch withmounting centers of 2.9 inch minimum to 3.5 maximum and black housing. Replaces Dyna DC12-2. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Universal fit for most Harley applications.
Dyna Tek #: DC12-2
  • Not for use with Dyna S ignitions
0 Special
