Harley Dyna Mini Coil Set 0.5 Ohms Single Output Towers - Dyna Tek DC12-1
SKU 32-9343
$209.99
2099 ENTRIES 🎟️
$209.99 - $209.99
$209.99
2099 ENTRIES 🎟️
Dyna miniature coil set feature single output towers and.5 ohms primary resistance. Designed for use with Dyna TC-88 series ignitions. This coil should not be used with Dyna S ignition systems. Coil set measures 4.2 inch x 2.3 inch x 1.6 inch with mounting centers of 2.9 inch minimum to 3.5 maximum and black housing. Replaces Dyna DC12-1. **NOTE: Check the coil primary resistance requirements from the manufacturers of the ignition being used. Sold as a set of two. Universal fit for most Harley applications.
Dyna Tek #: DC12-1
  • Not for use with Dyna S ignitions
0 Special
