Harley Dyna Mini Coil Set 0.5 Ohms Dual Output Towers - Dyna Tek DC11-2
Dyna miniature coil set feature dual output towers and.5 ohms primary resistance. Designed for use with Dyna TC-88 series ignitions and should not be used with Dyna S ignition systems. Coil set measures 4.2 inch x 2.3 inch x 1.6 inch with mounting centers of 2.9 inch minimum to 3.5 maximum and black housing. Replaces Dyna DC11-2.**NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Universal fit for most Harley applications.
Dyna Tek #: DC11-2
- Not for use with Dyna S ignitions
| 0 | Special |
