Harley Dyna Mini Coil Set 0.5 Ohms Dual Output Towers - Dyna Tek DC11-1
Dyna miniature coil set features dual output towers and.5 ohms primary resistance. Designed for use with Dyna TC-88 series ignitions and should not be used with Dyna S ignition systems. Coil set measures 4.2 inch x 2.3 inch x 1.6 inch with mounting centers of 2.9 inch minimum to 3.5 maximum and black housing. Replaces Dyna DC11-1.**NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Sold in a quantity of two. Universal fit for most Harley applications.
Dyna Tek #: DC11-1
- Not for use with Dyna S ignitions.
| 0 | Special |
