Harley Dyna 6 Volt 1-1/2 Ohm Dual Fire Coil - Dyna Tek DC2-1
This Dyna dual fire coil is angle type. The coil is 6 volt and 1-1/2 ohm. It replaces Dyna DC-2. This high tech top quality coil is designed for maximum performance. The coil will produce spark voltages in excess of 30 000 volts and spark energies second to none. It will work with points ignition aftermarket and factory electronic ignitions. Sold in a quantity of two. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Universal fit for most Harley applications.
Dyna Tek #: DC2-1
- Suggested to use with Coil Mount for Dyna Ignitions.
| 0 | Special |
