Harley Big Twin & Sportster Dyna 12 Volt 5 Ohm Stock Dual Fire Coil - Dyna Tek DC7-1 - Ironhead 1965-1979
This Dyna dual fire coil is stock type. The coil is 5 ohm and 12 volt for points ignition. Replaces Dyna DC-7. This coil is a high tech top quality coil that is designed for maximum performance. The coil will work with points ignitions. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Fits 1965-1979 Harley Sportster, Panhead, and Shovelhead models.
Dyna Tek #: DC7-1
| 1965-1979 | FL |
| 1965-1979 | FLH |
| 1971-1979 | FX |
| 1965-1979 | XL |
