Harley Big Twin & Sportster Dyna 12 Volt 5 Ohm Single Fire Coil - Dyna Tek DC10-1
Dyna single fire coil is angle type. The coil is 12 volt and 5 ohm. It replaces Dyna DC-10-1. This high tech top quality coil is designed for maximum performance. This coil is a stock replacement. Coil works with point and aftermarket electronic ignitions and factory electric ignitions. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Sold in quantity of two. Fits 1980-1999 Harley Big Twin, FX (Super Glide), FXR, Softail, Sportster, Touring, and Shovelhead models.
Dyna Tek #: DC10-1
| 1980-1984 | FL |
| 1986-1999 | FLST |
| 1985-1999 | FLT |
| 1980-1984 | FX |
| 1984-1994 | FXR |
| 1984-1999 | FXST |
| 1980-1999 | XL |
