Harley Dyna 12 Volt 3 Ohm Dual Fire Coil - Dyna Tek DC1-1
This Dyna dual fire coil is angle type. The coil is 12 volt and 3 ohm will produce spark voltages in excess of 30 000 volts and sparks energies second to none. Replaces Dyna DC-1. This coil works with points ignition aftermarket and factory electronic ignitions. Sold in a quantity of two. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Universal fit for most Harley applications.
Dyna Tek #: DC1-1
- Coil Length: 4.61 inches
- Coil Width: 2.9 inches
- Coil Height: 1.95 inches
- Suggested to use with Coil Mount for Dyna Ignitions.
| 0 | Special |
