Distributor Drive Cam Chest Gear - V-Twin 12-1995 - OEM 25850-36B
SKU 12-1995
$109.99
$109.99 - $109.99
$109.99
OEM #: 25850-36B
Distributor drive cam chest gear with thin profile gear features a solid style.
The tooth wide is.350 inch for extra clearance. Check clearance with hi-lift cams. The overall width may have to be reduced to 1.775 inch. *NOTE: The spacer is machined on part of the gear. *NOTE: Bushings my require reaming to fit the idler and circuit breaker studs in the case.
  • Thickness:.350 inches
1936-1940 EL
1941-1969 FL
