Deltran Battery Tender LCD Battery Meter - Deltran 081-0157
by Deltran
SKU 16-0595
449 ENTRIES 🎟️
449 ENTRIES 🎟️
Deltran #: 081-0157
Deltran battery tender LCD battery meter is for use with the Deltran battery tender harness.
The LCD displays the battery voltage when the button is pressed or when initially plugged in. *NOTE: The red LED flashes when voltage is low between the 3-16 voltage range.
- GREEN: Battery Charged (Greater than 12.0V) YELLOW: Batter is Low (11.6 to 12.0V) RED: Battery is Discharged (Less than 11.6V)
| 0 | All |
