Harley Big Twin & Sportster Daytona Twin Tec Electronic Ignition System - Daytona Twin Tech 1010
Dual fire electronic ignition system which includes trigger rotor for mechanical advance mechanism. Features a digital set RPM limiter in 200 RMP steps from 5 200 to 7 000 status LED for static timing electronic dwell for maximum ignition energy at high RPM reduced current draw at low RPM and a simple two wire hook up. Reliable starting in all conditions by operating down to below 6 volts and is rated to operate at 260°F System is waterproof and has resistance to vibration and shock. Compatible with original equipment and also aftermarket dual fire ignition coils with 3-5 ohms primary resistance. *NOTE: Not legal for sale or use in California or on pollution controlled vehicles. Installation instructions (PDF). Fits 1970-1999 Harley Big Twin, Dyna, FX (Super Glide), FXR, Softail, Sportster, Touring, and Shovelhead models.
Daytona Twin Tech #: 1010
| 1970-1984 | FL |
| 1986-1999 | FLST |
| 1980-1999 | FLT |
| 1971-1984 | FX |
| 1991-1999 | FXD |
| 1982-1994 | FXR |
| 1984-1999 | FXST |
| 1971-1998 | XL |
