Daniel Boone Forward Shift Kit - V-Twin 22-0867 - Big Twin 1941-1999
Daniel Boone forward control kit with rubber includes right side hydraulic pedal assembly left side shifter rubber brake pedal peg and Cat's Paw rubber covered footpeg set.
Accepts Kelsey type master cylinder. Order brake line and master cylinder separately. For use with ratchet type 4 speed transmission. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
| 1941-1999 | FL |
| 1941-1999 | FLH |
| 1971-1999 | FX |
| 1971-1999 | FXE |
