Harley Big Twin Crane HI-4N Ignition Module Kit - S&S Cycle 550-0502 - Evolution 1984-1998
Crane ignition kit includes ignition single fire coil and 8.5mm double silicone spark plug wires. The HI-4N ignition has a one piece machined aluminum housing which reduces the vibration and improves dissipation and reliability. Ignition is equipped with a single and dual fire function which is built into a single module. Allows easy mode advance rate and rev limit adjustments. Initial timing marks allow adjustment and reinstallation. Sensor covers are integrated into the housing to provide protection during installation. This is improved kick start algorithm designed to start easily and with a flexible wiring harness it makes installation easier. Fits 1984-1998 Harley Dyna, FXR, Softail, and Touring models.
S&S Cycle #: 550-0502
| 1986-1998 | FLST |
| 1984-1998 | FLT |
| 1991-1998 | FXD |
| 1984-1994 | FXR |
| 1984-1998 | FXST |
