Harley Chrome Sifton Engine Breather Oil Collector - V-Twin 40-0595
by Sifton
SKU 40-0595
$84.99
849 ENTRIES 🎟️
$84.99 - $84.99
$84.99
849 ENTRIES 🎟️
Chrome oil collector is designed to collect the oil mist from the breather hose which eliminates engine oil from collecting in air cleaner. On top is a high flow air filter that acts as a baffle allowing the oil and air to separate more efficiently and can easily be cleaned. On the bottom is a drain plug to allow drainage on a regular basis. A 90° barbed fitting fits breather hoses perfectly and includes chrome mounting clamp. *NOTE: For additional applications for remote location use a 1-1/2 inch p-clamp to secure canister. *NOTE: So the clamp does not slip when you tighten the fittings it's suggested to use sand paper or a file to rough up the band where the clamp fits. (See diagram) Installation instructions (PDF). Universal fit for most Harley applications.
  • Length: 2-3/4 inches
  • Diameter: 1-1/2 inches
  • Can Height: 2-3/4 inches
  • Can w/Fitting Height: 4-1/2 inches
  • Can w/Filter Height: 5-7/8 inches
