Chrome Replica Rear Engine Bar Set - V-Twin 51-0932 - OEM 49150-58
SKU 51-0932
$189.99
$189.99 - $189.99
$189.99
OEM #: 49150-58
Engine bar set features left and right sides.
WARNING: This engine/frame bar may provide limited leg and cosmetic vehicle protection under unique circumstances (fall over while stopped very low speed slide). They are not made nor intended to provide protection from bodily injury in a collision with an automobile or any other object. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Suggested to use with Mount Stud for Rear Engine Bar to go across the frame at the fender strut mounting area.
  • Suggested to use with Auxiliary Seat Spring Rod Nut Set which is used at the bottom for mounting.
1958-1964 FL
