Harley Dyna Chrome Rear Axle - V-Twin 44-2014 - OEM 41114-90 - Big Twin 1991-2005
SKU 44-2014
599 ENTRIES 🎟️
$59.99 - $59.99
599 ENTRIES 🎟️
Chrome rear axle, a direct OEM-spec replacement for a worn, bent, or rusted stock axle that keeps the wheel running true. Fits 1991-2005 Harley Dyna models.
OEM #: 41114-90
Axle with a hex head and a threaded end has a 9-1/4 inch bearing surface length and can be used to replace a worn out or damaged axle.
The total length measures 13-5/8 inch from under the cap head to the end.
  • Bearing Surface: 11-3/16 inches
  • Surface w/o Thread: 11-7/8 inches
  • End to End: 11-7/8 inches
  • Outer Diameter: 3/4 inches
  • Threads per Inch: 18
1991-2005 FXD
