Harley Chrome Rear Axle Kit - V-Twin 44-0221
Chrome rear axle, a direct OEM-spec replacement for a worn, bent, or rusted stock axle that keeps the wheel running true. Universal fit, replaces the stock axle on most Harley applications.
Rigid style rear axle kit has a 10-1/4 inch bearing surface length with an outer diameter of 3/4 inch.
The rigid frame disc brake rear axle is for use when 1973-up rear disc brake units are installed on rigid frames. Rear axle kit includes 3/4 inch outer diameter axle nut spacer and washers. Spacers may have to be cut to length. *NOTE: Hex axle head has milled flats for 7/8 inch axle slots. Use spacers with 7/8 inch flat area on nut side for axle plate slots. Standard replica rigid frames and hardtails have 7/8 inch rear axle slots.
- Surface w/ Thread: 10-1/4 inches
- Surface w/o Thread: 9-1/2 inches
- Overall Length: 10-1/2 inches
- Outer Diameter: 3/4 inches
- Threads per Inch: 18
