Harley Chrome Rear Axle 3/4 Inner Diameter Swingarm Style - V-Twin 44-1945
SKU 44-1945
649 ENTRIES 🎟️
649 ENTRIES 🎟️
Chrome swingarm end plate the axle passes through, a direct replacement for a cracked, bent, or corroded stock plate. Universal fit for most Harley axle applications.
Axle with hex head and a threaded end has a 11-1/2 inch bearing surface length and can be used to replace a worn out or damaged axle for swingarm frames.
Accepts 5/18 inch-18 nut. Hex head is not machined flat for rigid frame. Locators are set to fit axles in order to stock rigid frame axle plates.
  • Bearing Surface: 11-1/2 inches
  • Surface w/o Thread: 10-5/8 inches
  • Overall Length:
  • Outer Diameter: 3/4 inches
  • Threads per Inch: 18
