Harley Chrome Front Axle - V-Twin 44-0699 - OEM 40928-06 - Twin Cam Dyna 2006-2007
SKU 44-0699
399 ENTRIES 🎟️
399 ENTRIES 🎟️
Chrome front axle, a direct OEM-spec replacement for a worn, bent, or rusted stock axle that keeps the wheel running true. Fits 2006-2007 Harley Dyna models.
OEM #: 40928-06
Axle with threaded end has a 9-1/8 inch bearing surface length and can be used to replace a worn out or damaged axle.
Must be used with 1 inch bearings.
  • Bearing Surface: 9-1/8 inches
  • Surface w/o Thread: 8-3/4 inches inches
  • Overall Length: 11-1/2 inches
  • Outer Diameter: 0.998 inches
  • Threads per Inch: 20
2006-2007 FXD
