Harley Big Twin & Sportster Chrome 6 Volt Mechanical Regulator - Volt Tech 77210C - OEM 74510-47A - Sportster 1947-1964
SKU 32-0624
599 ENTRIES 🎟️
$59.99 - $59.99
599 ENTRIES 🎟️
Mechanical regulator features a heavy duty shock mounted steel base vibration resistant internal wire connections fiber and mylar insulating pads and large diameter contact surfaces. Regulator is for a 6 volt two brush generator. Cut out relay closes at 6.2 volts. Regulation limits voltage to 7.2 volts maximum. Regulator is two coil type without over current protection. Fits 1947-1964 Harley K Model, Sportster, Knucklehead, and Panhead models.
Volt Tech #: 77210C · OEM #: 74510-47A
1947-1963 FL
1952-1956 KH
1957-1964 XLH
