Harley Big Twin Chrome 12 Volt Ignition Coil 3.0 Ohms - Volt Tech 74056A
SKU 32-8090
$99.99
999 ENTRIES 🎟️
$99.99 - $99.99
$99.99
999 ENTRIES 🎟️
Ignition coil is steel jacketed and includes nuts packing and wires. The 12 volt coil replaces those on 1930-1947 mod els with chrome finish. Use coil mount kit to clamp to frame tube. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. ***NOTE: Coils are factory tested before packaging. Full warranty thru the dealer where you purchased! Over 20 000 coils sold since 1990! *NOTE: Use wire terminal OEM #9913 on 1930-1947 models for distributor wires. Fits 1930-1947 Harley Flathead and Knucklehead models.
Volt Tech #: 74056A
  • Use coil mount kit on Big Twin models
  • Use coil mount kit for Side Valve models
1936-1940 EL
1941-1947 FL
1938-1947 UL
1930-1934 VL
