Harley Panhead Chrome 12 Volt Ignition Coil 3.0 Ohms - Volt Tech 72374 - OEM 31604-48
Chrome ignition coil is steel jacketed and includes nuts packing and wires. This 12 volt coil is for single point distributors. The primary resistance is 2.5 Ohm. *NOTE: Coil mounts directly to the studs on the frame. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. *NOTE: Replaces OEM 31604-48. ***NOTE: Coils are factory tested before packaging. Over 20 000 coils sold since 1990!. Fits 1948-1960 Harley Panhead models.
Volt Tech #: 72374 · OEM #: 31604-48
| 1948-1960 | FL |
