Harley Big Twin & Sportster Chrome 12 Volt Generator - Volt Tech 29975-65A - OEM 29975-65A - Sportster 1941-1981
SKU 32-0207
$239.99
2399 ENTRIES 🎟️
$239.99 - $239.99
$239.99
2399 ENTRIES 🎟️
Volt Tech 2-brush generator is 12 volt type without gear. Generator fits 1936-1969 FLH including Flathead models. On pre-1958 models the engine case must be drilled to 5/16 inch-24 to accept late mount bolts. Gear kit must be ordered separately. Features a close interfence fit tool should be used to install gear. Gear should not slide on loosely. Pressing on the gear may force the solenoid out of the back. Installation instructions (PDF). Fits 1941-1981 Harley Sportster, Knucklehead, Panhead, and Shovelhead models.
Volt Tech #: 29975-65A · OEM #: 29975-65A
  • Order gear kit
1941-1969 FL
1957-1981 XL
