Harley Big Twin Chrome 12 Volt Alternator Generator Conversion Kit - V-Twin 32-1675
Chrome alternator bolts on in place of original 12 volt generator. Includes chrome solid state regulator gear gasket and mount screw set. Features high power output 17 amps @ 1000 rpm. *NOTE: On 1941-57 models generator screw holes must be enlarged to 5/16 inch to fit generator screws supplied. Use Helicoil thread repair kit to convert alternator with 5/16-24 thread to 1/4-24 thread in order to accept early mount bolt set. *NOTE: The outer cover with the large hex nut houses the rotor magnets which are encased in a stainless steel shell. This inchrotor inch turns when the engine is running. Installation instructions (PDF). Fits 1941-1969 Harley Knucklehead, Panhead, and Shovelhead models.
- Suggested to use with Thread Repair Kit
| 1941-1969 | FL |
