Chopper Axed 2.2 Gallon Gas Tank - Wyatt Gatling 63093A
SKU 38-0694
$209.99
2099 ENTRIES 🎟️
$209.99 - $209.99
$209.99
2099 ENTRIES 🎟️
Wyatt Gatling #: 63093A
Gas tank has a left side petcock opening and a fuel capacity of 2.2 gallons. It features front and rear mount tabs and uses dual bayonet style gas caps.
Check the tank for flaws and fit before painting. It requires sanding and primer. Do not grind or sand the seams or joints. Check the petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Top Length: 14-1/2 inches
  • Bottom Length: 12-3/4 inches
  • Rear Width: 2 inches
  • Front Width: 7-3/4 inches
  • Rear Height: 1 inches
  • Front Height: 7-1/2 inches
  • Front Tunnel Height: 3 inches
  • Rear Tunnel Height: 1-3/4 inches
  • Tunnel Length: 15 inches
