Chopper Axed 2.2 Gallon Gas Tank - Wyatt Gatling 63093
Wyatt Gatling #: 63093
Gas tank has a right side petcock opening and a fuel capacity of 2.2 gallons. It uses a single bayonet style gas cap and has front and rear mount tabs.
Right side is 3/8 inch NPT female left side is 1/4 inch NPT female for petcocks. Petcock tunnel is 2-1/2 inch wide. Tabs are front and rear undrilled. Check the tank for flaws and fit before painting. It requires sanding and primer. Do not grind or sand the seams or joints. Check the petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock. The petcock must be ordered separately. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Top Length: 16-1/4 inches
- Bottom Length: 14-3/4 inches
- Rear Width: 2-1/4 inches
- Front Width: 8 inches
- Rear Height: 1-1/2 inches
- Front Height: 7 inches
- Front Tunnel Height: 3 inches
- Rear Tunnel Height: 1-1/4 inches
- Tunnel Length: 15-5/8 inches
- Suggested to use with Petcock Wing Type Chrome.
- Suggested to use with Stock Style Gas Cap Vented
