Cast Rear Mechanical Brake Drum Black - V-Twin 23-0248
Mechanical rear brake drum is for star hub wheel with a black finish and features better cooling and braking with the cast iron consturction.
This brake drum features full cast iron construction for excellent heat dissipation and no distortion during heavy braking. Fits EL FL and UL models with mechanical brakes. Accepts stock shoes and backing plate. For use with star hub wheels only. *NOTE: Cast drum may hav eclearance issues relieve areas for better fit. V-Twin Replica cast shoes are recommended for this drum. Sprocket is riveted in place and drum is machined to allow for an integral splash ring. Bolt on installation replaces the stock pressed brake drum.
| 1937-1952 | EL |
| 1941-1957 | FL |
| 1937-1948 | UL |
