Cast Iron Oil Pump Sub Assembly - V-Twin 12-0835
SKU 12-0835
$269.99
$269.99 - $269.99
$269.99
Cast iron oil pump sub assembly includes 5 gears and 1 shaft. Assembly will accept alloy cover.
Top welch plug and inner baffle installed. *NOTE: Fittings outer cover chain oiler screw mount studs gaskets and snap rings not included must order separately. Body is not drilled and tapped 1/4 inch x 20! Shipped as shown for Panhead models.
1949-1967 FL
