Captain America 2.2 Gallon Gas Tank - Paughco 806CF
by Paughco
SKU 38-0185
Original price $439.99 - Original price $439.99
$439.99
4399 ENTRIES 🎟️
$439.99 - $439.99
$439.99
4399 ENTRIES 🎟️
Paughco #: 806CF
Replica gas tank has two 1/4 inch National Pipe Thread petcock outlets and a fuel capacity of 2.2 gallons. This Captain America tank has straight mount tabs on the front and rear and a center filler neck. Order gas cap separately.
Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check the petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Top Length: 15.5 inches
  • Bottom Length: 15-3/8 inches
  • Rear Width: 2.5 inches
  • Front Width: 8.5 inches
  • Rear Height: 3 inches
  • Front Height: 7 inches
  • Front Tunnel Height: 2.5 inches
  • Rear Tunnel Height: 2.5 inches
  • Tunnel Length: 15.5 inches
