Cam Chest Breather Valve Standard Size - V-Twin 12-1561 - OEM 25300-36
SKU 12-1561
$99.99
$99.99
$99.99
$99.99
$99.99
$99.99
OEM #: 25300-36, 504-36
This standard size sifton cam chest breather valve is constructed of precision ground steel with screen installed.
Order thrust washers separately. *NOTE: 28.53mm outer diameter range 28.53 - 28.54mm.
- Suggested to use with Cam Chest Breather Valve Washer Set.
- Suggested to use with S&S Breather Cam Chest Washer Set.
| 1948-1977 | FL |
| 1971-1977 | FX |
