Cadmium Stock Style Hardware Kit for Aluminum Heads - V-Twin 8309 CAD
Stock hardware kit contains all the stock style engine nuts bolts washers and studs for your engine with aluminum heads.
Includes primary cover screws lifter base screws circuit breaker screws case studs and nuts timing plug cam cover screws cylinder base nuts and screws oil pump nuts and bolts transmission side cover nuts and washers transmission top screws transmission fill plug generator screws head bolts and washers.
| 1937-1973 | G |
| 1937-1952 | WL |
