Harley Big Twin Brass Plated 6 Volt Ignition Coil 1.5 Ohms - Volt Tech 74057D - OEM 31602-30
SKU 32-8110
899 ENTRIES 🎟️
899 ENTRIES 🎟️
Ignition coil is steel jacketed and includes nuts packing and wires. The 6 volt coil replaces those on 1930-1947 models with a brass finish. Use coil mount kit to clamp to frame tube. Full warranty thru the dealer where you purchased! *NOTE: Use wire terminal OEM #9913 on 1930-1947 models for distributor wires. ***NOTE: Coils are factory tested before packaging. Over 20 000 coils sold since 1990!. Fits 1930-1947 Harley Flathead and Knucklehead models.
Volt Tech #: 74057D · OEM #: 31602-30, 1722-30A
1930-1940 EL
1941-1947 FL
1938-1947 UL
1930-1934 VL
