Brake Light Flasher Module - V-Twin 33-1181
GearBrake intelligent deceleration and brake light module is small and attaches with velcro.
The GearBrake module detects any deceleration from braking backing off the throttle down shifting etc and will automatically flash the brake lights. The module will continue to light brake lights as usual and can also be used with any additional lights if you prefer to leave your brake lights untouched.
- The unit is simple to install you just find a good spot under the seat usually works apply the velcro tape to secure it then connect it to the wiring harness.
| 0 | All |
