Brake Control Kit Mechanical - V-Twin 22-0706
Chrome brake control kit for mechanical brake frames with a cross shaft tube only. Footboards may be used with this kit.
Must order the clutch cable separately. NOTE: On 1936-1957 Big Twins the rear brake lever arm faces rearward and in. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Suggested to use with Black Clutch Cable.
| 1936-1940 | EL |
| 1941-1957 | FL |
| 1936-1948 | UL |
