Bobbed 4.0 Gallon Gas Tank Kit - V-Twin 38-0190 - Big Twin 1995-2005
SKU 38-0190
Original price $539.99 - Original price $539.99
$539.99
5399 ENTRIES 🎟️
$539.99 - $539.99
$539.99
5399 ENTRIES 🎟️
Gas tank has a left side petcock fitting and has a fuel capacity of 4.0 gallons. Tank includes chrome bung style late caps and all necessary mounting hardware for installation.
Tank kit features a three light dash kit which includes a plain dash base without wiring and a late bob type six post chrome key switch. Speedometer and cable are not included. This tank is not for fuel injected models. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and preven t corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for eaay installation of petcock.
  • Top Length: 18-1/2 inches
  • Bottom Length: 18 inches
  • Rear Width: 10 inches
  • Front Width: 14 inches
  • Rear Height: 1-1/4 inches
  • Front Height: 8-3/4 inches
  • Front Tunnel Height: 7 inches
  • Rear Tunnel Height: 1-1/2 inches
  • Tunnel Length: 17 inches
1995-2005 FXD
