Bobbed 3.8 Gallon Gas Tank Chrome - Ultima 20-100 - Big Twin 1984-1999
Ultima #: 20-100
Chrome 4 inch stretch gas tank with a fuel capacity of 3.8 gallons includes gas cap.
Check the tank for flaws and fit before painting. Do not grind or sand theseams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Suggested to use Gas Cap
| 1986-1999 | FLST |
| 1984-1999 | FXST |
