Bobbed 3.2 Gallon Gas Tank Kit - V-Twin 38-0075 - Sportster 1952-1978
Gas tank is dual cap style with a left side petcock location and a fuel capacity of 3.2 gallons.
Kit has a one piece tank that will bolt to existing mounting holes. Includes three light dash cover kit bobbed tank mount bracket chrome gas cap set and front bobbed dash speedometer cable and 2:1 speedometer. Tank has a left side petcock opening a fuel capacity of 3.2 gallons and is dual cap type. Please test fitment before painting. Tank weld seams may require filler to meet your individual requirements. Do not grind or sand the seams or joints as this may cause leaks. We suggest using Kreem gas tank combo kit to clean condition and seal. This will help to stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Top Length: 18-1/2 inches
- Bottom Length: 16-1/2 inches
- Rear Width: 7 inches
- Front Width: 13-1/2 inches
- Rear Height: 2 inches
- Front Height: 8-1/2 inches
- Front Tunnel Height: 8 inches
- Rear Tunnel Height: 2 inches
- Tunnel Length: 17 inches
| 1952-1978 | XL |
