Harley Big Twin Black Vinyl Frame Mount Solo Seat - V-Twin 47-0599
SKU 47-0599
$119.99
1199 ENTRIES 🎟️
$119.99 - $119.99
$119.99
1199 ENTRIES 🎟️
Frame mount vinyl solo seat is equipped with molded high density foam padding and a plastic seat pan. This solo seat mounts directly to the frame without springs. The front nose hooks clip directly into the frame and rear bolts to the side of the frame in front of the shock mounts on both sides. *NOTE: To fit 1958-1964 kick start lower frames the installer will have to extend the tabs. CAUTION: Dropping of this product may cause a break in the cover material and void warranty. Fits 1965-1984 Harley Big Twin, FX (Super Glide), Panhead, and Shovelhead models.
  • Width: 11 inches
  • Bend To Front Tip: 13-3/4 inches
  • Bend To Top: 6 inches
  • Tab Distance: 9-3/8 inches
1965-1984 FL
1970-1984 FX
