Black Rear Engine Bar Set - V-Twin 51-1062 - OEM 90200788 - Twin Cam 2014+
OEM #: 90200788
Rear engine bar set with black finish. Set includes saddle bag supports left and right guards and hardware to replace the support for under the saddlebag. These bars protect the leading edge of the bags.
Set of two. WIll fit FLHX and FLHXS models. **WARNING: This engine/frame bar may provide limited leg and cosmetic vehicle protection under unique circumstances (fall over while stopped very low speed slide). They are not made nor intended to provide protection from bodily injury in a collision with an automobile or any other object. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
| 2014-UP | FLH |
| 2014-UP | FLHR |
| 2014-UP | FLHRC |
| 2014-UP | FLHRSE |
| 2014-UP | FLHTCU |
| 2014-UP | FLHX |
| 2014-UP | FLHXS |
| 2014-UP | FLTRUSE |
| 2014-UP | FLTRX |
| 2014-UP | FLTRXS |
