Harley Black Copper Core 7mm Spark Plug Wire Kit - Volt Tech 40158
Vintage style spark plug wire set is 7mm copper core type and is 40 inch long with two 90° spark plug boots installed on the ends. Cut the 40 inch length to the desired front and rear lengths and install the supplied coil terminal clips and boots. *NOTE: Not for use on 1999-up Big Twin and 2007-up XL models. Universal fit for most Harley applications.
Volt Tech #: 40158
