Harley Big Twin Black 6 Volt Ignition Coil 1.5 Ohms - Volt Tech 74057
New Production ignition coil is steel jacketed and includes nuts packing and wires. The 6 volt coil replaces those on 1930-1947 models with a black finish. Use coil mount kit to clamp to frame tube. Includes 2 stainless steel 8-32 x 5/8 inch round head screws for the terminals. *NOTE: Check the coil primary resistance requirements from the manufacturer's of the ignition being used. **NOTE: The internal winding and connecting wires were updated in 2018. ***NOTE: Coils are factory tested before packaging. Full warranty thru th edealer where you purchased! Over 20 000 coils sold since 1990!. Fits 1930-1947 Harley Flathead and Knucklehead models.
Volt Tech #: 74057
| 1930-1940 | EL |
| 1941-1947 | FL |
| 1938-1947 | UL |
| 1930-1934 | VL |
