Harley Big Twin Black 12 Volt Ignition Coil 3.0 Ohms - Volt Tech 74056
Ignition coil is steel jacketed and includes nuts packing and wires. The 12 volt coil replaces 31602-30 on 1930-1947 models with black finish. Use coil mount kit to clamp to frame tube. Includes suppression wires. Coils puts out 2 ohms. The right side is positive and the left side is negative. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. ***NOTE: Coils are factory tested before packaging. Full warranty thru the dealer where you purchased! Over 20 000 coils sold since 1990! *NOTE: Use wire terminal OEM #9913 on 1930-1947 models for distributor wires. Fits 1930-1947 Harley Flathead and Knucklehead models.
Volt Tech #: 74056
- Use coil mount kit for Big Twin models
- Use coil mount kit for Side Valve models
| 1936-1940 | EL |
| 1941-1947 | FL |
| 1938-1947 | UL |
| 1930-1934 | VL |
