Harley Panhead Black 12 Volt Ignition Coil 3.0 Ohms - Volt Tech 72374B
Black ignition coil is steel jacketed and 4.8 ohms. Includes nuts packing and wires. This 12 volt coil is for single point distributors. *NOTE: Coil mounts directly to the studs on the frame. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. ***NOTE: Coils are factory tested before packaging. Full warranty thru the dealer where you purchased! Over 20 000 coils sold since 1990!. Fits 1948-1960 Harley Panhead models.
Volt Tech #: 72374B
| 1948-1960 | FL |
