Harley Big Twin & Sportster Black 12 Volt Generator with Low Output - Cycle Electric DGV-5000L - Sportster 1941-1981
Cycle Electric generator is 12 volt low output 2-brush style with built in regulator. Generator fits 1936-1969 FLH including Flathead models. On pre-1958 models case must be drilled to accept 5/16 inch-24 size mount bolts. Overall length is 7.58 inch from gasket surface to fins. Gear kit must be ordered separately. Order gear kit to complete the installation. Low output generator can be used with mini 12 volt battery. Installation instructions (PDF) Installation instructions (PDF). Fits 1941-1981 Harley Sportster, Knucklehead, Panhead, and Shovelhead models.
Cycle Electric #: DGV-5000L
- Use with mini battery
| 1941-1969 | FL |
| 1957-1981 | XL |
