Big Twin Rotating / Tilt Engine Stand - V-Twin 16-0435
SKU 16-0435
$259.99
2599 ENTRIES 🎟️
$259.99 - $259.99
$259.99
2599 ENTRIES 🎟️
Rotating / tilt engine stand for Big Twins.
*NOTE: Customer must install washers and/or bushings not included at pivot points behind knobs to secure motor for alternate tilt angles.*NOTE: Bolts to mount engine not included. Allen cap screws has a 7/16 inch hex same as the Harley lug wrench. *NOTE: In order for the 5/8 inch set screw to engage with the table the motor mount stand must be attached to a steel work bench or a sheet that is steel coated. **NOTE: Use 7/16 inch allen wrench (HD lug wrench).
1936-1952 EL
1941-1984 FL
1985-1999 FX
1937-1973 G
1937-1952 W
