Harley Big Twin Big Sucker Air Cleaner Kit Stage 2 - Arlen Ness 18-506 - Twin Cam 1999-2015
Air cleaner kit that bundles the cover, backing plate, and mounting hardware together for one straightforward install instead of sourcing each piece separately. Fits 1999-2015 Harley Dyna, Softail, and Touring models.
Arlen Ness #: 18-506
Stage 2 Air filter kit is for carburetor or EFI models.
Air cleaner kit have the all-in-one backing plate that features a built-in carburetor support and built-in breather tunnels at each head to decrease crankcase pressure. Each tunnel exits at the mouth of the carburetor to create a virtually closed loop system. Includes inchBig Sucker inch aluminum backing plate high-flow air filter 4 chrome banjo bolts simple instructions and all the necessary hardware. Bolt location center to center on Big Twin models is 15cm.
- For use on 2000-2006 carbureted models 2002-up Delphi fuel injected models. Not for use on 1999-01 and 2008-17 FLT fuel injected.
| 1999-2015 | FLST |
| 1999-2007 | FLT |
| 1999-2007 | FXD |
| 1999-2007 | FXST |
