Bastardo Panhead Engine Assembly 88", " - V-Twin 10-2449 - Big Twin 0+
Original price $7,539.99 - Original price $7,539.99
$7,539.99
60319 ENTRIES 🎟️
$7,539.99 - $7,539.99
$7,539.99
60319 ENTRIES 🎟️
Bastardo engine assembly is fitted with Shovelhead 3-5/8 inch cylinders with 4-1/4 inch stroke combined to create an 88 cubic inch engine. OKO shorty carburetor is installed and tuned. Dyna tested for oil pressure.
Panhead with Shovelhead power features Shovelhead intake and exhaust valves. The exhaust ports are Shovelhead style to accept single bolt Shovelhead flanged headers. Redesigned intake ports will accept a Shovelhead o-ring intake manifold. This motor breathes and runs like a Shovelhead. *NOTE: Carburetor is included. Manufacturer's Statement of Origin is supplied. Features a front saddle for the 3 brush generator strap. Accepts Shovelhead OHO line to the heads. Set does not accept cast inner cover for 1965-1969 FL models. *NOTE: 3 brush generator saddle may be removed for 2 brush generator installation. Case cylinder ports are 3.8750 inch and machined to fit 3-5/8 cylinders.
