Harley Big Twin Barnett M8 Scorpion Clutch Kit - Barnett 321-30-02017 - Twin Cam 2017+
by Barnett
SKU 18-1155
Original price $529.99 - Original price $529.99
$529.99
5299 ENTRIES 🎟️
$529.99 - $529.99
$529.99
5299 ENTRIES 🎟️
Kit features over twice as much friction surface area compared to stock clutch. For M8 models. *NOTE: Bearing not included. Re-use your stock bearing or order the appropriate bearing required. Scorpion clutch provides a positive engagement and release. Scorpion clutches incorporate 6 heavy duty coil springs. In addition an extra spring set with a different spring rate is included which allows the clutch to be tuned for street or race application depending on usage. Tunability is easy without removal of the primary cover. Barnett friction plates are compatible with any primary oil. Kit is designed to be used with stock type clutch basket. Fits 2017+ Harley Softail and Touring models.
Barnett #: 321-30-02017
2018-UP FLST
2017-UP FLT
2018-UP FXST
