Harley Bare 1938-1939 EL Knucklehead Cylinder Head Set - V-Twin 49-1349
EL bare Knucklehead cylinder head set features exact casting marks and details for 1938 61 inch Knucklehead models. Features a small intake port. The valve spring cover is not included. *NOTE: Accepts cup valve cover primer caps and large 18mm air cooled spark plugs all items available separately. *NOTE: Accepts large 1-3/8 inch hex Doering #3 spark plug set. *NOTE: Material of valve seats features a better hardenability and heat resistance than 1.2713. Material is tough with high compressive strength and high tempering resistance. Hardness equals 370-415 HB. Tensile strength equals 1250-1400 N/mn2. Condition is tempered. Installation instructions (PDF). Fits 1938-1939 Harley Knucklehead models.
- Suggested to use with Lower Valve Spring Cup Set Parkerized.
- Suggested to use with Brass Head Primer Cups.
- Suggested to use with 18mm Doering Spark Plug Set.
| 1938-1939 | EL |
